Window alignment
Old Mar 2, 2012 | 11:13 AM
Triangle12's Avatar
Default Window alignment
After rain this morning, I went out to the car and saw rain on the upper inside door panel on drivers side. Then noticed the 1/4 inch gap between the window glass and black rubber piece of door panel. Front portion of glass fits snug, so i figure its out of line. I recently replaced window motor on passenger side but have never had to deal with adjusting the glass. Is there an easy way to do this? I'm sure some type of clips hold the glass in place but didn't know how hard it was to reach with tools.
Old Mar 2, 2012 | 11:32 AM
Roachz28's Avatar
Do you have a 4th gen? I have had the same problem. I took the panel off realigned the window and it was good for a little bit now its back to having the little gap. I'm not exactly sure how to fix it but you aren't alone.
Old Mar 2, 2012 | 11:45 AM
Triangle12's Avatar
Default window
yep, its a 98. Was it hard to reach the clips that hold the glass?
Old Mar 2, 2012 | 11:51 AM
Roachz28's Avatar
I didn't enjoy it lets say that. but no task is the same for anyone.
Old Mar 2, 2012 | 12:33 PM
androzer's Avatar
a thief broke mine, and now I have gap between the window glass and black rubber piece of door panel form out side.
and is it ok for rain to come inside the door !
Old Mar 2, 2012 | 05:34 PM
here is some info on the earlier models, dont know if same. Adjust Door Window
Old Mar 2, 2012 | 06:20 PM
Triangle12's Avatar
Default window
thanks for the door window link!
Old Mar 3, 2012 | 07:51 AM
androzer's Avatar
guys I am not good car parts names !
the weatherstrip is seal of the door? or those to black ruber lines that prevent water to enter inside the body of the door?
Old Mar 3, 2012 | 08:43 AM
are you talking about the window weather strips
Old Mar 3, 2012 | 09:32 AM
The outer door to window "seal" doesn't, can't, and isn't supposed to prevent water from getting inside the door. That's why doors have drain holes at the bottom.
