Window adjustment.
Window adjustment.
The drivers side window, (manual windows) doesnt go up all the way. Really close, but not quite. It seems to fit the rear portion, but theres a little gap, probably 1/8 inch or slightly less towards the front, and a tell tale gap between the glass and the black part around the mirror. You can see this when the window is as high as it will go, and when the door is open.
This wouldnt be a problem, except for the wind noise, and it lets some water in the car when washing, or if I get caught in the rain.
Question is, how do I fix it?
Thank you so much, I finally got that fixed.
I think theres something wrong with the mechanism somewhere though. When the window tops out, the crank acts like its going to stop, then goes "clunk", and rotates upward about an inch. The window seats at that point, the last 1/8 to 1/4" but the crank doesnt feel right. It pops out of that position on the way down too.
cornmuffin
07-24-2014 10:22 AM
