where does this wire go??
1 Attachment(s)
I had to cut this wire to remove my engine a while back, couldnt get my fingers in there, and now that i want to repair it i cant find the other end! Where does this hook up to?
Attachment 24428 |
little wire is the start wire that goes to the ignition, clean the crud off and see what color it is, should be a cut one the same color, what yr is your rig again
1994, does it run into the harness?
its purple also
yep into the harness. should be a purple wire at the harness.
thanks craby, i must have overlooked it, ill check it out tomorrow
