Where do i put the refrigerant?..
Old Jul 16, 2012 | 05:18 PM
DSteinyZ28's Avatar
Default Where do i put the refrigerant?..
I want to recharge my AC system but where is the port to plug it in?
Old Jul 16, 2012 | 08:40 PM
torque_is_good's Avatar
the fitting you have for the can will only fit on one of the AC fittings
you have 2 metal lines. The fatter one is the low side where you add the refrigerant
Old Jul 16, 2012 | 11:15 PM
slick's camaro's Avatar
X2^ which on the 3.4 l it will be the port closest to the firewall.
Old Jul 17, 2012 | 10:07 AM
DSteinyZ28's Avatar
Ok thanks guys, I didn't want to spray something in the wrong spot knowing my luck lol
Old Jul 17, 2012 | 11:00 AM
Does your system have any in it now? If there is no charge in there now you need to get the air/mositure out of there. Charging a system that has air/mositure in it is a waste of money.
Old Jul 18, 2012 | 07:39 AM
DSteinyZ28's Avatar
It was most of the way full but I just topped it off
djsquare1
Aug 30, 2012 03:41 AM
Saibot
Jun 29, 2009 11:05 PM
