WHEEL HELP PLEASE!!!!!!!!
OK I HAVE A 94 Z-28 AND I BOUGHT A SET OF THE CHROME CAMARO WHEELS OF A NEWER MODEL Z-28(99??). I WENT TO PUT THEM ON AND THE FRONT TWO WHEELS WENT ON GREAT BUT WHEN I TRIED TO PUT ON THE BACK THEY WOULD NOT FIT OVER THE HUB. I THINK THE CAR THAT HAD THEM ORIGINALLY HAD DISK BREAKS ALL THE WAY AROUND. MINE ONLY HAVE DISK IN FRONT AND DRUM IN THE REAR IS THIS THE PROBLEM??? ANYONE HAVE A SOLUTION ON HOW TO GET THEM TO FIT?? THEY ARE VERY CLOSE COULD THE WHEELS BE FILED ON A LITTLE AND MADE TO FIT?? THANKS FOR ANY HELP!!
RE: WHEEL HELP PLEASE!!!!!!!!
What you can try doing is simple. I had a similar siiue but wit the front rims I put on my 99. What I did was grind the fins on the front calipers. I know you have rear drum, but you may be able to grind the fins on the drums enough for them to fit. What I did was put the rims on as well as I could., Then I got a grease crayon (yellow( and drew around the area that was hitting so I knew what to grind off.
