-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   what is the tool to remove the battery cable (https://camaroforums.com/forum/93-02-general-41/what-tool-remove-battery-cable-72067/)
androzer Oct 15, 2012 09:52 AM
what is the tool to remove the battery cable? is there any special tool to remove the battery screws of the cables? cus I guess the resevor is leaking hope its only the hose under the battery.
thx.
torque_is_good Oct 15, 2012 10:18 AM
8 mm box wrench
Camaro 69 Oct 15, 2012 10:36 AM
I use a 5/16", which is essentially the same difference. SAE rules! ;)
BasicConcepts Oct 15, 2012 10:51 PM
8mm ratchet wrench is the best, they sell an actual battery wrench at like Walmart (Idk if there's a Walmart around you but any parts store)
androzer Oct 18, 2012 08:17 AM
Oh thx, guys but I found that the Mechanics used a primitive tools before so the 8mm will not be effective any more the surface of the screw is almost flat. they used a pliers the last 15 year........ :-)
Edwardgp Oct 18, 2012 09:14 AM
You will need to use a small pair of Vise-Grips and once remove I would install new battery bolts.
1augapfel Oct 18, 2012 09:57 AM
Yeah, that screw is easily replaceable so you may want to add on to your next parts order. It just pops out of the molded PVC cable end.
