What size high flow cat?
What size inlet/outlet cat should I get? I want to put a high flow cat and a new muffler on my car. I checked the size of the downpipe to the cat and the outlet and they are both different. The inlet measures 3" and the outlet 2.25". I'm thinking 3" in and out, then reduce it to 2.25 after that. What do you guys think? Also, do these cars have an air tube on the cat? I forgot to look when I was under the car.
This is the one I am looking at.
Magnaflow 94309 Magnaflow Performance High-Flow Catalytic Converters
Thanks.
Thanks.
I'm not planning on buying it from Jeg's, they just had a better description on there. I can get a new one on Amazon for $92 shipped. And it's not going on a stock exhaust, I plan on getting a new Magnaflow muffler and having a local shop replace the rest of the pipe from the cat to muffler.
I would go 3 in in and out, then buy a cat-back, instead of just replacing the muffler. If you do a 3 in. Cat-back then no reduction required, else do at least a 2.5 in system...
