What rears are you all running ???
Old 10-24-2009, 11:46 AM
maudyZ28's Avatar
Default What rears are you all running ???
Ok everyone, when in back home to UK i have a huge mods list to push 450 rwhp, full top end job. Anyhow, my 10 bolt is way past its best now so i have 3 options in what i think is my best most cost effective order, remember i live in UK so double the US price as i have to ship:
1: Auburn Pro ( or other clutch type) rear for 10 bolt axle case with 3.23 or bigger on an A4
2: Ford 9" from a mustang??? ( can i get one from a new shape 05-09?? as i have access to salvage ones over here). Has anyone done this? does it bolt straight up. Im not bothered about doing the work just want to know what to expect as i use the car daily
3: Moser (or other) full 12 bolt, will ave to get from US
Thanks everyone!!
Old 10-25-2009, 07:46 PM
LHill00Z28's Avatar
Correct me if I am wrong but doesn't Moser make an F-Body bolt-in 9"?? Might be a bit more spendy but much easier.
A 12 nolt would be a good choice too. Go with the 3.73's if your doing the change anyway.
Old 10-25-2009, 08:06 PM
whammer3024's Avatar
ROTM Winner
yes there's 9" that they make for f-bodies
i highly doubt the 9" from a mustang would bolt right up but i guess i'm not sure.
most people use 12 bolts, but a 9" would probably be easier to change gears
Old 10-26-2009, 03:12 AM
95slvrZ28's Avatar
I would look into a Moser 12-bolt if you're not interesting in swapping ratios easily. If you want to pay a little more price premium for the 9" that Moser offers for the F-body to swap gears you could go that route. Needless to say, you're not going to be breaking either of those rearends anytime soon. You could also think about a Strange S60.
Old 10-26-2009, 04:39 AM
maudyZ28's Avatar
what about the strength of an aftermarket unit in the 10 bolt, the auburn pro? or other, its by far the cheapest for me to ship over as id rather spend moser money on my engine
Old 10-26-2009, 09:46 PM
auto's Avatar
stock rear here, works well for me
Old 10-27-2009, 04:37 AM
maudyZ28's Avatar
yer but mines almost out, lsd mechanism is shot and very loose inside. Basically if i do my heads cam and top end package it will not hold out, the lat drag sesion i did it was whinning like a biach
Old 10-27-2009, 10:05 PM
750chop's Avatar
Run it til it shreds then go with F-body 9" thats my vote. or consider a cheaper route of rebuilding the factory rear end with better parts? Ive seen stock rear ends take a good bit of power with a few select upgrades.
Old 10-29-2009, 10:03 AM
KPI's Avatar
KPI
KPI is offline
With an auto and stall you can make the 10 bolt live. You need a solid pinion spacer insyead of the factory crush sleeve and you need gears properly set up.
I've had the 10 bolt living in my car with the M6 and GM 4.10 gears for 4 years now.
It will work fine for an auto on ET's.
Old 10-29-2009, 11:16 AM
z28rob18's Avatar
dont waste money on the 10 bolt a new aubern posi will break at some point wat makes it weak is the size. theres things u can do to delay the break. as far as rears 9" is your strongest choice. then the s60. 12bolts last but get some wine after enough track time
Quick Reply: What rears are you all running ???
