what next?
alright i think im gonna go with suspension, i need to get my 60 ft time down, wher i get my tune ill look at injectors...... ok so basically i need LCA's torque arm and rear sway bar, i removed the front one, what lcas should i go with i have heard go with moly adj lcas, but then no idea about the others, im looking and strange and the others now
i would get like single adj lca's i lik spohn but bmr and umi are great too. if you get one suspension piece in chromoly get the torque arm. my torque arm is heave as hell. but moly is light and lighter is better. as for the rear sway bar if you get a drag bar spohn has had some issues with it in the way of adjusting ***** if you get single adj shocks itll be no problem but with double it has been an issue
i am using the spohns poly bushing adjustable arm and the transfer isnt bad. get a thunk once in a while from the front link flexing. ive got the lt header type and it really takes away ground clearance. i will be trying a straight one when i can fit it in the buget, it looks to me like the kooks y pipe will clear. got the adjustable panhard bar with the spherical ends and like it.
