what next?
Old May 27, 2010 | 12:06 AM
kirks11's Avatar
Default what next?
i made a post a little while ago about getting my heads ( still waiting on valves!!) so now im just wondering what you guys think i should do next? i have ms4 cam ported 241 GTP heads, ls6 intake ported throttle body, pasesetter headers exh.
Old May 27, 2010 | 12:09 AM
what size injectors?
Old May 27, 2010 | 12:12 AM
kirks11's Avatar
hmm im not sure, most likely stock
Old May 27, 2010 | 01:48 AM
BasicConcepts's Avatar
Technical User
under drive pullys maybe a new set of pistons rings and bearings
Old May 27, 2010 | 06:04 AM
pick up some 30# sov injectors.
Old May 27, 2010 | 09:05 AM
kirks11's Avatar
ill have to go look at mine and make sure, what color would the stock inj be?
Old May 27, 2010 | 09:15 AM
z28rob18's Avatar
i think stock are all black but so r some after market ones. looks to me like your good power wise right now i would do suspension. lca's torque arm sway bar panhard rod adj shocks like strange or qa1
Old May 27, 2010 | 01:11 PM
u have 28.8# stock so 32# would work too. heres a couple to have a look at. give em a call and see if they have a recomendation for your set up.
http://fuelinjectorconnection.com/sh...&productId=179
http://fuelinjectorconnection.com/sh...&productId=178
Old May 27, 2010 | 04:42 PM
libertyforall1776's Avatar
QA1 sucks, according to Sam Strano:
http://stranoparts.com
Better off with Koni...
Old May 27, 2010 | 09:07 PM
z28rob18's Avatar
sam strano is more about handling and road course stuff qa1 and strange are more for straight line racing. i went with the strange. if you have the money id go afco i believe they just lowered prices. but if good handling is your thing then some konis and sway bars
