What kind of exhaust is this?
Old 08-12-2011, 09:06 AM
greycon88's Avatar
Default What kind of exhaust is this?
Previous owner had this installed dual dual performance exhaust from SLP.
I know the big metal box in the middle is the cat box, but where are the mufflers, are they gone?
& also, is this an "H pipe"?
I don't know **** about exhausts.
Old 08-12-2011, 10:00 AM
thats your muffler, the cat or cats should be to the front in the area of the transmission. the split pipe in the picture is just for looks. any h or x pipe would be up front in the same area by the trans.
Old 08-12-2011, 01:39 PM
Guitar's Avatar
That picture doesn't tell much!
Old 08-12-2011, 06:13 PM
Failed Devices's Avatar
your car uses a y pipe, h pipe is for a true dual setup.
cats are up with the exhaust manifolds on either side of the engine
Old 08-12-2011, 09:06 PM
greycon88's Avatar
How do I take the muffler off?
Any one got a guide for 01 camaros??
It is y pipe, I suppose, because it's one pipe that splits into two with a dual outlet
Old 08-12-2011, 09:13 PM
BasicConcepts's Avatar
Technical User
Why would you want to take the muffler off and why are you asking about the maf and ecu
Just a little info maf stands for mass air flow sensor it measures how much air come into the engine then sends a signal to the ecu or engine control unit and tells your car how much fuel to flow
Old 08-12-2011, 09:29 PM
torque_is_good's Avatar
I have a question?
Is that a rug or stamped concrete on the floor in your folks' garage?
I can't really tell but it almost looks like a rug.
Old 08-12-2011, 09:55 PM
Technical User
It's a rug see the wrinkles
Old 08-12-2011, 10:09 PM
greycon88's Avatar
Want it louder... sounds like a v6 lol.
SLP 31066 SLP Loud Mouth Shotgun Resonator, Camaro (each) - NO RETURNS 1993-02 V8 - 31066, SLP Muffler
Do I need two of those for a Y pipe?
Old 08-12-2011, 11:18 PM
Technical User
what size is the motor? and no youd only need 1 with a y pipe
Quick Reply: What kind of exhaust is this?
