Weird problems
Old 06-27-2013, 09:20 AM
mp734's Avatar
these are the best i could get. its a bit hard to fit my hand and phone into there to take a picture. i couldn't really get a good picture f the flap though. my dads buddy who is a mechanic is coming over in a little bit to check it out. hopefully he will figure out something.
Attached Thumbnails Weird problems-0627131001.jpg   Weird problems-0627130957.jpg   Weird problems-0627131000.jpg
  #32
Old 06-27-2013, 09:56 AM
to try and get rid of the pressure unhook the fuel line at the fuel filter. pump some fuel out of tank, jump 12 volts to the fuel pump test wire under the hood, should be on the passenger side wire harness. make sure you have the fuel line in a container to catch it. im wondering if the punp is failing and the tank is full.
  #33
Old 06-27-2013, 11:48 AM
mp734's Avatar
there is no way the tank is full. my gas gauge doesnt work so i keep track of how much gas i put into my car and when this problem started i ran the car out of gas.
  #34
Old 06-27-2013, 12:47 PM
if you are getting gas coming out of the fill tube then its full of something. the fluid/gas level would have to be up to the fill hole. may be the fuel pump is failing. have you tested fuel pressure.
  #35
Old 06-27-2013, 03:18 PM
mp734's Avatar
I tested the pressure at the motor. It was a little high. I dont remember the exact number
  #36
Old 06-27-2013, 05:24 PM
should have been about 50 lbs. ok after some looking, im pretty sure to turn on the pump manually you would need to jump power to the fuel pump relay plugin under the hood, terminal 85, tan&white wire. unhook at fuel filter and pump a bunch of gas out. should relieve pressure.
  #37
Old 06-27-2013, 06:19 PM
mp734's Avatar
where will the gas come out. also my dads buddy told him he thinks the fuel filter might be clogged and is causing the pump to work harder. does that seem like a possibility.
  #38
Old 06-27-2013, 09:09 PM
as i said take the fuel filter off, fuel will come out of the fuel line when the pump is on. then you can check the filter out. dump filter out from the tank side in to a clear container. should give you an idea of what was in it. if your filter has the quick conntect heres some info on em. http://shbox.com/1/quick_connect.jpg
  #39
Old 06-30-2013, 09:07 PM
mp734's Avatar
i changed the fuel filter and the old one seemed clogged. i drove it exactly 1.5 miles and it acted like it ran out of gas again. so next thing im going to try is to replace the fpr. atleast tomorrow i will have another car. picking up a 95 z28 with a 6 speed.
  #40
Old 06-30-2013, 09:11 PM
mp734's Avatar
also i noticed that the gasket around
the fuel cap seemed to be splitting would that be causing anything.
Quick Reply: Weird problems
