Volt meter is fluctuating
Old Jul 12, 2012 | 10:24 PM
BasicConcepts's Avatar
Technical User
kinda the power is transferred from the alt to the battery and electronics at the same time, if the battery is weak it can become a load causing the alt to struggle and eventually die.
Old Jul 12, 2012 | 10:33 PM
Speedfreak02's Avatar
Ok I'll give it a try tomorrow by taking it to a battery shop.. I'll keep ya updated if your curious
Old Jul 12, 2012 | 10:35 PM
Technical User
ohh ya deff keep us updated
Old Jul 12, 2012 | 10:56 PM
contrary to popular belief you are not supposed to unhook the battery when the car is running. can burn up the internal voltage regulator or toast a negative diode in the alternator.
Old Jul 12, 2012 | 11:00 PM
When you changed the belt, did the tensioner fight you with a bit of force? When an alternator is under a load, you'd have one heck of a time trying to spin the pulley by hand. If the tensioner is weak, you'll have a loose and slipping belt, and an alternator that isn't spinning or putting out like it should.
Could also be that a bearing in the alternator is starting to lock up, momentarily stopping the alternator. Had that happen once, where the gauge was getting jittery, shortly before the alternator locked up and burned through the belt. Happened on a road trip, late on a Sunday night, 6 hours from home, with no parts stores open. Hate when that happens.
Old Jul 12, 2012 | 11:04 PM
Technical User
had that happen to me, 04 cavilier in the hills of west va (the scary everyone that brakes down here dies part of wva) i blew out 2 tires. my gf was convinced some hillbillys were going to kill us lol (this was right when the hills have eyes came out)
Old Jul 13, 2012 | 12:41 AM
My mechanic came n checked it out and said that my new egr valve was leaking he could hear it whistling... Sound right that, that may have caused the problem he's gonna check it out again tomorrow when it's light out
Old Jul 13, 2012 | 12:48 AM
Technical User
exhaust leaks are more of a tick than a whistle, but that would have nothing to do with the power issue.
Old Jul 13, 2012 | 12:52 AM
EGR wouldn't affect alternator output or the gauge, unless it's making the rpm's drag waaaaay low, where the engine is on the verge of killing.
But, you never said anything about where your rpm's are when this is happening. Fill us in there.
Old Jul 13, 2012 | 02:05 PM
  #20
Well everyone even though I did the self alternator test, it turned out to be the alternator. Apparently when I changed the belt the new tension I put on the old alt caused it to put strain on it.. So new alternator and it feels like a new car.. Thsnks for all your help and advice
