viberation over 80
Old Nov 8, 2008 | 02:59 PM
rondavis's Avatar
Default viberation over 80
so i changed my trans cuz i blew the sycros for 3rd and 4th in my m6 and now when i drive the car it has a really bad viberation when i get up over 80 mph and im courios as to if any body knows what might cause it
Old Nov 8, 2008 | 04:30 PM
02StanGT's Avatar
Default RE: viberation over 80
Was the driveshaft torqued back properly? Only other thing I can think of is tires need to be balanced. Can you tell where the vibration is coming from?
Old Nov 8, 2008 | 06:44 PM
importmd's Avatar
did you mark the driveshaft before you pulled it? and put in back in the same spot?
Old Nov 9, 2008 | 08:35 PM
rondavis's Avatar
ti would not have matterd if i marked the drive shaft cuz i put a differant trans in the car so no and it feels like it is the drive shaft but is hard to tell
Old Nov 10, 2008 | 09:57 PM
Masospaghetti's Avatar
You could try hand balancing it using hose clamps and moving the clamp around the shaft and seeing if the vibration goes away, or have the driveshaft professionally balanced (which is not very expensive - maybe $50, tops?)
Old Nov 10, 2008 | 09:59 PM
outta_control_z28's Avatar
sounds like the drive shaft ?
Old Nov 10, 2008 | 10:08 PM
importmd's Avatar
take it out and rotate it
Old Nov 18, 2008 | 12:38 PM
QC97Z's Avatar
I had the same issue on mine. I pulled my stock driveshaft and changed the U-joints. Unfortunately, while changing my U-joints, my driveshaft got squished too much in my vice, and I ruined it. Bought a 4" Aluminum driveshaft, slapped it in, vibration went away.
Check the U-joints first, make sure they're good. If they're fine, look into getting it balanced professionally.
If it's not the driveshaft, it's possible you could be having rear end issues. Check into the driveshaft first, as rear end difficulties can get expensive, especially if you can't work on it yourself.
superROB23
Apr 2, 2014 08:17 PM
