Vette wheels fit a 96 Camaro ??
the hubs on the rear wheels are larger than on the rims you wish to install. You will need to either take 2 rims to a machine shop and have them open the hole 1/4 inch or file baby file.
If you have all the wheels opened up you can rotate the tires. Otherwise, the rear 2 will always be the rear 2. the choice is yours.
Me, I just did the rear 2 only.
As far as I know you can run any Vette replica and to run actual Vette take offs you need to grind out the center of the wheel a little to get it to fit over the rear hubs. I have never heard of anyone having backspacing issues etc. with them.
