Umm where does this go?
Old 04-11-2009, 02:29 AM
Intrepid781's Avatar
Default Umm where does this go?
I came home the other day to my mothers boyfriend tinkering around under the hood of my car. He was messing with this and that so I went off on him, and he unhooked this and I have no idea where it goes. The sleeve that goes on the plug is purple...can anyone help? Its on the drivers side and right now I have it tied around the abs junction till i find out where it goes...
Old 04-11-2009, 03:36 PM
greenarrow's Avatar
September 2009 ROTM
I doesn't go into the abs does it? Maybe the cooling fans? Is it three wires or just two into the plug?
Old 04-11-2009, 04:06 PM
Not to change the subject, but is that the "orange" Fram oil filter I see?
If that's what you have, don't use them. They're bad news!
Here's some helpful oil filter study info: http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.html
Old 04-11-2009, 04:07 PM
evilkal's Avatar
Eh... What Camaro 69 said lol
Old 04-11-2009, 04:10 PM
BeraniHull's Avatar
Son of a bit...I wish I had known that before I changed my oil.
Old 04-11-2009, 04:34 PM
That connector does not look like it has been hooked to anything for a very long time. Maybe an option you do not have like cruise control?
Old 04-11-2009, 07:54 PM
I have cruise control...there are no other wires that aren't hooked to anything on the car I know it haaaaas to go somewhere! Stupid random wires....I'm almost positive there are 3 but I'll have to look in the morning. What oil filter would you guys recommend?
Old 04-11-2009, 08:46 PM
Read the link in my post above ^
Old 04-11-2009, 10:01 PM
im with gorn on this one. if its runing fine and no ses id say its to something not in your model but is wired for it. looks like its never been hooked to anything. thanks to cam69 for the filter write up, good reading, learned alot about filters. now i gota go get a new one.
Old 04-12-2009, 06:13 AM
I did say "Like cruise control" Pull one of your other connector. Look at how clean it is. That is what the soft seal does. Not only is the connector very dirty but the metal on the connection has a layer of oxidation on it. That can take years to form on a treated connector. You will not see on a air tight connector that is pluged in. That connector has either never been pluged in or has been unpluged for a very long time. Infact if that is a functional connector I would take it apart and clean before I tried to use it. That oxidation will cause the connector to fail pretty quickly.
