Turn signal halp
Okay, so the other day my front right turn signal froze up. I checked the others with my hazards(all other three flashed ) so i went and kicked it, bingo.
So now it has happened again on the left one, i cut the turn signal on and it stays lit up, but cut the hazards on and it stays on and the other three blink. Ive kicked the hell out of it and it just wont flash. What do CF? |
Replace the bulb.
^Agreed
what yr car? a failing bcm can do what you are saying. replace bulbs first and see if that has an effect.
97 rs
The bulb itself can lock up?
when a bulb is burnt out or not working the system is not drawing enough amps to engage the flasher so it doesnt blink. sorta a way to tell you a light is not working.
I c, well then i will change it, how?
so your saying that all the lights come on and blink except one and it stays on without blinking. are the front ones the only ones doing it?
Correct
| All times are GMT -5. The time now is 08:07 AM. |
