True duals
Old 10-05-2009, 08:51 PM
User Name's Avatar
Default True duals
I have a 95 Z28 and, I would like to convert in into a 3' true dual system. However, I already have a Eibach Pro-Plus kit on the car, lowering it 1.3 inches. I'm worried if I go with the true duals it will not give me a great ground clearance. Any thoughts on this problem.
Old 10-05-2009, 10:35 PM
robmnrd's Avatar
If you're like me, you'd get the duals custom-made, which would get you better clearance than any aftermarket y-pipe. BUT if you can't afford that route, then a y would be better suited to your needs.
Old 10-08-2009, 07:54 AM
User Name's Avatar
I asked one of my buddies about this and, he suggested oval pipes. I never heard anything about oval pipes. As anyone else?
Old 10-08-2009, 03:58 PM
maudyZ28's Avatar
do you plan on getting long tube headers too?? these will sit about 1/2 to 1" lower depending on the make ( SLP tuned length say they drop 1" ish) The main problem is the axle you can dump or run over or under.
Old 10-09-2009, 09:43 AM
User Name's Avatar
I plan on going with the Kook's 1 7/8" headers. I'm going to run them over the axle.
Old 10-09-2009, 09:54 AM
maudyZ28's Avatar
you should manage it, just be steady over any bumps areas. You might have to drop the panhard support bar some with a relocation bracket to get over the top with 2 pipes, but 3" is fine
Old 10-09-2009, 03:41 PM
cbr600rx7's Avatar
I would stick with a 3 inch Y-pipe and call it a day. But thats just me.
Old 10-10-2009, 03:27 PM
95slvrZ28's Avatar
^^ x2
3" true dual all the way back is going to be WAY more flow than you need, you'll end up spending more money than you need, and you'll get 0 benefit over a good 3" Y-pipe and cat-back. I'm not quite sure what the allure of true duals is, but a good Y-pipe setup can easily support over 500 RWHP...Oh yeah, and the Kooks 1 7/8" stepped headers are going to be way more flow than you need as well unless you're running over 415 CID or revving the car to 7000 RPM. A 1 3/4" primary is almost perfect for a 330-415 CID motor to optimize the exhaust scavenging wave.
Old 10-11-2009, 05:49 AM
maudyZ28's Avatar
I think the allure is the sound
If you do go with a single 3" as crb and slvr suggest i am unsure if it will support upto 500hp, correct me if im wrong but i went through this whole process when designing some 2.5" true duals for my friends pontiac gto
Ok, so a rule of thumb is that per hp your car with flow 2.2 cfm of exhaust gases So say you are around 350-400hp makes 770-880 CFM exhaust. And a typical cylindrical pipe will flow 115 cfm per inch squared. 1" diameter pipe will flow 115 CFM thus support 52 hp.
Here we have a 3" pipe, x-sec area = 7.06" squared. Thus flows 805 CFM, just enough from the single pipe to support 360hp
With 2.5" true duals we have combined X-sec area of 9.8" squared which supports 1130CFM, ie ~510HP which is the limit we had for costs etc on my mates GTO
( his pics are here if your interested in looking: http://www.hsv.org.uk/topic.asp?t=724822&f=69&h=27)
Anyhow planning my exhaust for the 'maro im gonna go with single 4" (1445 cfm - 650hp) or dual 3" (1625cfm - 740hp)
The 1 3/4" primary headers are ok however as they flow 360cfm each pipe which is likely more than the heads on the motor anyway
hope this help
Old 10-11-2009, 03:08 PM
doug91rs's Avatar
im gonna have to agree with 95slvr on this one. plenty of guys pushing 450hp have 1 3/4 prime headers with a 3inch y pipe n cat back. the setup has plenty of flow n just the right amount of back pressure. just because the pipes r bigger doesnt mean they're better.
you see it alot with those mustangs. 3inch H pipes n dual exhaust all that sound but no performance
Quick Reply: True duals
