Transmission wiring
Transmission wiring
I need help on a 93 Camaro V6 with automatic. I need aschematic or wiring diagram that shows the wiring and connector going into the trans over the shift control entry point? I believe this is the shift control connector. The wires are pulled out of the connector. The connector has contacts in A, B and D. C is not used. I think the wire colorsare tan/black, gray/black and gray, but it's hard to tell for sure. Thanks
dsinclair999
02-21-2011 11:24 AM
