Transmission Lock
Old Oct 11, 2011 | 08:39 AM
White_Camaro_Z28's Avatar
Exclamation Transmission Lock
Hello guys,
i need a small help i just bought a 97 camaro Z28 but the thing is the battery is dead and i think the starter as well i need to move it but the problem is the trans is positioned on "P" is there anyway like to release the lock without starting the car so i can put it in neutral
will appreciate any kind of help thanks!
Old Oct 11, 2011 | 09:06 AM
Chevy101's Avatar
Just turn the key to the on position and you should be a able to shift
Old Oct 11, 2011 | 09:22 AM
i tried that it doesnt work the key wont turn to the on position because of the "battery" am guessing .. is there any other way?? and thanks for ur reply
Old Oct 11, 2011 | 11:41 AM
I am not an expert because all my 4th gens are stick but I think there is a safty switch the brake petal throws that unlocks a solenoid in the shifter. You going to have to get power to it or tear the console apart and remove the blocking plate.
Old Oct 11, 2011 | 12:43 PM
Chevy101's Avatar
The battery shouldn't have anything to do with the key. If it isn't turning it may be an ignition problem
Old Oct 11, 2011 | 01:50 PM
yes you need to push on the brakes to get the car out of park. i am thinking its not electric but linkage or hydraulic off the brakes on my 93. may be different on the 97. if you can get under the car you can unhook the cable from the linkage and pull it out of park. is the car on a hill or incline?
Old Oct 11, 2011 | 01:55 PM
nope car is on straight land any pic of the saftey switch or how to get to it??
Old Oct 11, 2011 | 01:58 PM
Old Oct 11, 2011 | 02:19 PM
So White, even though you never said one way or another, I assume you did try stepping on the brake pedal?
Old Oct 11, 2011 | 02:45 PM
yes i did my friend with all the power i got too!!
