Transmission?
The other day my car threw a code. had it checked out and it said the tranmission is slipping. so i put ATF in the car cause it was low. it helped for a bit and the code went away. now when ever i hit the pedal, the car just kinda jerks along. is this the transmission slipping? or any ideas of what it could be doing? any help would be awesome
Just a suggestion... run some Lucus stop slip tranny fix stuff. Usually if it's slipping a little due to low fluid then it'll take a few miles for the fluid to get everywhere it needs to be before it'll show it's doing "better"
Well said. Slippage really can't be solved with oil additives. Rebuilding is the fix all. Do not change the fluid. Automatic transmissions run on this principle: Change the fluid regularly as per the service schedule according to GM, or don't change it at all. The clutch dust and older fluid act as seals and help with sealing the ports and passages inside the transmission. New fluid has a high level of detergents that remove these makeshift seals. I've seen it all too many times. Keep an eye on your fluid, though. Smell it and inspect it regularly for obvious signs of burning. The 4L60E is notorious for slippage and malfunctions especially if there's a decent amount of age on it.
dsinclair999
Feb 21, 2011 11:24 AM
