Tranny Swap Questions
Old Jun 21, 2011 | 06:36 PM
CrimsonRevolver's Avatar
Default Tranny Swap Questions
Hey, I'm gonna swap my tranny for a new 4L60E. I'm just wondering if there's any stipulations, like if it matters what year car the transmission comes out of, or what kind of car. I have a '95 Z28. Would it matter if I put in a tranny from an... I don't know... '99 Chevy S10?
Essentially, what kind of 4L60E do I need for my car?
Thanks, guys.
Old Jun 21, 2011 | 06:49 PM
libertyforall1776's Avatar
What's the reason for the swap?
Old Jun 21, 2011 | 07:06 PM
your going to need one with the same plugins. most the 95s are obd1 which has a bit different way of interacting than the obd2 systems (96-02). you can get most any 4l60e to work by switching the plugins on the trany. a good trany shop can do it. if your wanting to do the switch yourself it would be best to find a 4l60e from a 95 camaro. do you have funds to have your trany done at a place like performabuilt 4l60e 700r4 4l80e performance gm transmission performabuilt
Old Jun 21, 2011 | 07:16 PM
Tranny's shot. Slipping all over the place.
Well, I was gonna have my mechanic do it. He said he was gonna get one from a transmission shop that was out of a wrecked car with low mileage.
It's an auto, btw.
Old Jun 21, 2011 | 07:41 PM
trany shop should know which one will work or set one up that will.
Old Jun 21, 2011 | 07:45 PM
Alright, cool. Thanks, bro.
Old Jun 21, 2011 | 11:18 PM
Hey, Craby. My car won't shift at WOT. That's just part of the bad tranny, right? Should my new one alleviate that problem?
Old Jun 22, 2011 | 12:42 AM
explain a little better. wont shift how? wont shift up, down, or go at all. what gear will it go to or not?
Old Jun 22, 2011 | 12:49 AM
It won't upshift at WOT in all gears it seems - I have to let off. Before my tranny started slipping, it shifted fine at any other throttle, but when I have it floored it won't upshift.
Old Jun 22, 2011 | 01:19 AM
could be vehicle speed sensor or throttle position sensor. also changing rearend gear ratios or making a mistake on a computer tune or computer failing. im sure there are a few internal transmission problems that can cause the issue.
