Traction
Old Apr 29, 2008 | 12:47 PM
bidicamaro's Avatar
Default Traction
On my 94 Z LT1 I'm not getting good traction. Now I'm just running plain radials but I have to take off slow or I'll light 'em up and I mean I have to fether the damn thing. I was told that adding a new torque arm will help alot but I'm not sure. Was wondering if anyone could fill me in on things you've done that have worked for you. I'll be looking into some drag ET's but that'll be later on and only on while at the track. Also, I don't want to lower the car or get anymore ofa rough ride than it already has. I know that would help a lot but what about the torque bar and lower controls and a new panhard bar (assuming there's one under there). Also, what's the widest tire that can be ran in the rear without any issues and without sticking out of the fender? Hope this isn't a "this is ALWAYS asked kind of thread. Thanks all!
Old Apr 29, 2008 | 12:57 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Traction
you need better tires. thats all there really is to it. if you want to go a cheaper route that isnt as good of a fix you can get LCA relocation brackets. they do help, but its more of a bunny hop sort of mod. reduces wheel hop and gives you a firmer plant. you may want to look into new rims that are wide enough for a 275 tire if u dont have them already and look at some good tires like BFG KDWII or Nittos
Old Apr 29, 2008 | 01:05 PM
Ninja Administrator
the KDW's are pretty good btw for a non-drag street radial. ive seen new stangs pull 1.8 60's on them. they could help u out too. what tires are u running now?
Old Apr 29, 2008 | 01:12 PM
bidicamaro's Avatar
4 different ones... ****ing place I got the car had to pass inspection... I'm loooking at some firestone fusions cause I don't have a lot of money yet. But I want the mickey thompson drag ET's but just for the strip. I have a buddy that has the fusions on his GTP and they don't do to bad. What are KDW and where do I get them?
Old Apr 29, 2008 | 01:13 PM
bidicamaro's Avatar
oh ****... BFG's duh!
Old Apr 29, 2008 | 01:18 PM
Ninja Administrator
BG goodrich KDW. id get these over the firestones. and i dont believe they are too expensive. check tirerack.com
Old Apr 29, 2008 | 01:22 PM
Ninja Administrator
http://www.tirerack.com/tires/bfg/bfg.jsp
theres the BFG's.. they are summer tires, which means traction falls quite a bit when its cold because of the softer compound tending to harden up at lower temps. the KDW's are ALMOST drag radials
Old Apr 29, 2008 | 09:27 PM
95slvrZ28's Avatar
I'm running 274/40/ZR17 KDWS all around (stupid Colorado and it's snow making me need an all season radial!) but they hook up pretty well. They still spin all through first though. I would suggest the Firestone Firehawk Wide Oval's they're supposed to be a great tire.
Old Apr 30, 2008 | 08:19 PM
Slick6's Avatar
I have 275-40-18 Avon Tech M550's on all corners pullin 425hp and don't get to much spin unless I really try to. 158 bucks a piece for those big meats on tirerack.com I swear by that place, I love 'em.
Old Apr 30, 2008 | 08:20 PM
Slick6's Avatar
ORIGINAL: 95slvrZ28
274's? lol
