Torque pattern info needed
Hey there guys. OK checked out the usless Chilton Manual for the torque specs and pattern and no luck for my 99 3.8L engine. I found the 3.4 and the LT1 but nothing on the 3.8 or LS1 engines. The book just says follow the proceedure on them.
Craby or someone with the correct info, if you are reading this can you scan your book for me and post the 3.8L intake upper and lower torque specs and pattern please? I am good everywhere else.
Thank you
Massey
Thank you
Massey
found this here http://www.torkspec.com/torkspecme.a...-3.8L-231ci-V6
Type: Bolt Dim: Length: Head: Hexagon Grade:
37 Ft-Lbs
444 In-Lbs
50.17 N-m
Connects: Cylinder Head To Engine Block
Years: 1995-1998 Vote Record: Vote
Note: 3800 II - 3 Steps: 37FtLbs; +130deg; +30deg(Center 4 Only)
37 Ft-Lbs
444 In-Lbs
50.17 N-m
Years: 1999-2005 Vote Record: Vote
Note: 3800 II - 2 Steps: 37FtLbs; +120deg
37 Ft-Lbs
444 In-Lbs
50.17 N-m
37 Ft-Lbs
444 In-Lbs
50.17 N-m
