Tires?
So the garage find special had been sitting on flat tires for quite a while and now after airing them up to 30psi, the ride seems a bit "jittery". When I had them balanced and rotated, every tire wobbled. Our guess is that that was where the flat spot was. Rims all looked true.
My question is: Will the flat spots eventually work their way out? Tires are about 90% (Goodyear Eagles) and in date code. I'm thinking that flexing them a bit and getting them warmed up might rearrange things so that the ride will smooth out. Your thoughts? |
if its internal you cant fix it. if external maybe. i have roasted the back tires and got one out once. lol.
Best bet is to replace them. That wobble can destroy other things on the car if left untreated . . . crappy stock bushings and shocks being first
agree that they could an should be a safety issue , if the gas tank was that bad ,i am suprized they put them back on without saying you got bad tires hear ,i drove my red one with weathered tires for about 3000 miles an i can tell what a new set of meats will be like ,it was just so late in year ,an the guy was not that bad with the inspection ,just more serious issues like the sway bar an a few other things ,but i looking forward to geting a desent set this winter when there on sale ,or early spring ,?theres no cracking in the treads
