TID and CID codes?
My scan tool is showing a few TID and CID codes, how would I be able to translate these?
TID: CID: $02$04 $02$10 $02$11 $02$12 $02$16 $02$20 $02$21 $02$26 $02$30 $02$31 $02$36 $02$40 $02$46 $03$01 $03$02 $04$20 (critical failure) $04$30 $06$35 $06$41 $06$55 $06$61 $06$0C (critical failure) $06$0D (critical failure) |
What scanner are you using that is giving such raw data? I thought all scanners converted the CID data to codes. I know I have seen a chart somewhere that covered the CID. I will look when I get a chance.
I found this, don't knwo if it helps.
http://www.aa1car.com/library/2005/m...anvehicles.pdf Seems easier to just get an OBDII scanner than try to figure all this out...lol |
Originally Posted by jkeaton
(Post 639576)
http://www.aa1car.com/library/2005/m...anvehicles.pdf Seems easier to just get an OBDII scanner than try to figure all this out...lol Thanks for the link I saved off that file for future reference. |
I am using that ELM-327 bluetooth scan tool with the torque android app. It reads check engine light fault codes normally, but when I do a realtime scan test it brings up these codes.
Ill look into that laptop one, that sounds interesting. Thanks for that link, I will check it out! |
If you already have the Elm 327 bule tooth you have the hardware as long as you have a laptop with buletooth. The ebay cable I have is just the Elm 327 USB
Check out ScanTool.net LLC - Scan Tools, PC, iPhone, & Android based OBD-II (OBD2) Interfaces, OBD diagnostic software Free download ScanTool.net, LLC - Downloads Some samples towards the end of this thread https://camaroforums.com/forum/tools...omputer-68104/ |
Originally Posted by Gorn
(Post 639634)
Awesome, great info!! Thanks!
(Post 639643)
Where's the OBD1 version for us 94 guys (and gals)? I have never had a vehicle I have such a hard time getting codes from...lol
Gorn, my 99 v6 Camaro had the abs system on obdii standards. I don't know if that was because of the updated computer with TBW but it could be read with my OBDII scanner and is almost identical to the ABS system in my 2000Z28. I can't speak for the older systems tho on what system was used.
Massey |
| All times are GMT -5. The time now is 08:53 AM. |
