Throttle Cables
ok so the last thing on my car are the cable that go the the throttle, I don't know which goes where and how is there a diagram or maybe someone could tell me? until then my car wont be getting started.....
throttle cable goes on the half circle, 3.4 i think the cruse goes in the the other half circle. look at the cable and line it up with the throttle lever and you should be able to tell which one they go to.
Now my only problem ithe shift selector on the trans, it seem that there is a piece missing that allows the ball to snap into the cable, I don't know what it look like or how it goes where? I can't move without this!
cant say ive never had mine apart. i just unbolt the arm and mount from the trans and leave it together. did you look on shbox, good place to do research. http://shbox.com/trans/A4_trans_linkage.html
gotta have that round plastic piece. better do some more hunting around the work area. i would think thats a common gm trans part so you should stop by the local gm parts dept and see if its still available.
