TA's Progress
Old Mar 8, 2008 | 03:06 PM
importmd's Avatar
Default RE: TA's Progress
mine are black with yellow bushings and grease fittings on both ends. does that sound like yours?
Old Mar 8, 2008 | 03:08 PM
SpecterGT260's Avatar
Ninja Administrator
iowa city. we got hammered for like 3 weeks straight.
8 inches over night, then warm enough to thaw, then another 6, then thaw, then repeat........... we had 8 inches of solid clear ice at my parents the other day. chipping that off the driveway was alot of fun........ show up for the first time in a month and my mom hands me a shovel [&:]
Old Mar 8, 2008 | 03:11 PM
Ninja Administrator
ORIGINAL: importmd
pretty much, since the fbody springs sit on the axle instead of the LCA's like my old mustang did the LCA is just a tube. mine had a 3 part bushing, 2 cups on each end and a ball between them to make it solid rubber through the whole end (or poly whatever its made out of) and there were 2 grease fittings, one on each end. have u put in the fittings yet? use a small socket over the fitting and hit the socket with a hammer but dont hit the fitting itself. the socket will put the force down on the base of the fitting.
Old Mar 8, 2008 | 03:15 PM
importmd's Avatar
mine are all put together, i was asking if yours looked liked mine, i just want to know the brand.
Old Mar 8, 2008 | 03:20 PM
Ninja Administrator
they are black with black bushings. im not sure who sells the ones with yellow bushings. i think lakewood might use yellow...
Old Mar 8, 2008 | 03:21 PM
importmd's Avatar
i see, thanks
Old Mar 8, 2008 | 07:48 PM
meteoralp45's Avatar
nice ride man, i like your car too
Old Mar 9, 2008 | 09:20 PM
Ninja Administrator
today I stopped by a buddies house to pick up his valve spring tool (my giant autozone lever wasnt going to work.....) and While i was there he also handed me a really nifty crank bolt tool (its kinda like just a crank bolt, but has a weird shaft thing and another screw for some reason......) but that will help me get that pulley back on, he gave me a tap in case im retarded and warp a thread on the crank, and also gave me the compressor fitting for the spark plug hole so I dont have to do TDC to get the valves off (i still will turn the crank, just incase a seal breaks and the valve drops).
pretty sweet. I have a test thursday and friday morning I leave for Hawaii, but that means thursday afternoon/night I can hopefully get those springs swapped out MORE PICS TO COME!
Old Mar 10, 2008 | 10:20 AM
95slvrZ28's Avatar
Lookin' good on both fronts man!
And leaving for Hawaii, looks like it's time for me to catch up in post count you post ***** [8D]
Old Apr 6, 2008 | 11:32 PM
  #20
Ninja Administrator
whell now.....
my goal was to be drving the TA by this week. However, thunder racing is getting a call tomorrow [>:]
im 2 locks short. i have only 1 valve left to do, and its on the #2 cyl.... just staring at me [:@]and theres nothing I can do. This is annoying. but im calling TR tomorrow and hopefully they can send me out 2 more locks.... unless there is a place around here I can get 2 locks of the same dimensions as the ones taht come with the thunder racing golds.......
