TA's Progress
Old Mar 8, 2008 | 01:54 PM
SpecterGT260's Avatar
Ninja Administrator
Default TA's Progress
Well, I went up last night to do a little more work on the TA and had the GF helping me out. I got that picture of her on my car for u yenko [8D]
so the old cam is out, new cam is in, new timing chain is on, new oil pump is on, oil pan is torqued back to spec. I am going to run up to a buddy's and borrow his valve spring compressor because the thing I bought to do it just wont cut it [&:]. so here are some pictures of the car torn down
A couple of the GF crankin on it
^^^^^^ that one is for u yenko
these are to show u guys just how much room u get from doing LT's. I got all of the spark plugs out in about 20 min from the top of the motor. easy as pie now that the manifold is out of there
oh, and this is what I got for Vday. low profile so I can slide this monster under the kmember of my car with no problems
its about 4 times heavier than my old one though
Old Mar 8, 2008 | 01:58 PM
Ninja Administrator
Default RE: TA's Progress
i should mention the reason she is down inside the engine bay like that is because she fits there.... and I dont, and the oil pump pickup tube bolt is in a really weird spot so i needed her smallness to finish the job
Old Mar 8, 2008 | 02:24 PM
6v49der's Avatar
Damn dude, I wish I knew a girl who cared about my car like I do... and what kind of tires do you have?
Old Mar 8, 2008 | 02:35 PM
Ninja Administrator
those are nitto 555R's (275/40 i think)
Old Mar 8, 2008 | 02:37 PM
02StanGT's Avatar
When I did my valve springs I had to borrow my friends spring compressor, since the one I bought was not small enough to fit under the cowl. The springs under the cowl can be a pain... I had one pop off and whomp me in the thumb. [&:]If it doesn't look like it's compressing evenly, then I'd try and do it again. But then again, I'm sure you knew that. Everything's looking good! When ya you going to take it out of hibernation?
Old Mar 8, 2008 | 02:53 PM
Ninja Administrator
we still have several feet of snow on the ground. ill take it out after the spring floods [&:] 5 inches away from record snow fall this year[>:]
Old Mar 8, 2008 | 03:00 PM
importmd's Avatar
What brand LCA's are you running
02StanGT's Avatar
That sucks. I think we've had 1 inch of snow this year. That was all from two days ago. Other than that, weather is hot, cold, hot, cold, cold, nice, hot, cold, etc...
Old Mar 8, 2008 | 03:03 PM
Ninja Administrator
ORIGINAL: importmd
they are tractek's, and they are the black ones. not that it matters cuz the color doesnt mean anything. they were the cheaper ones on the site i got them from, and they all do pretty much the same thing so i didnt break the bank on them
Old Mar 8, 2008 | 03:04 PM
JD1969's Avatar
Lookin good Spec oh yea the car looks good too Where are you again that there is that much snow?
