T-Tops - Wind noise?
Old 12-03-2011, 09:12 PM
TxPlates's Avatar
Default T-Tops - Wind noise?
So this is my first camaro with T-Tops. Just brought it home, it's a 1994 Z28 - on my drive home from picking it up (a 21.5 hour drive), you can hear wind on the drivers side - basically right behind the left side of your head. The car has been obviously garage kept for the last 17 years, only had 32k mileage and the tops don't leak. Is this just a common occurrence, or something I need to address?
Old 12-03-2011, 09:15 PM
iLL95's Avatar
I Like to Party
Super Member
Check the seals, pinpoint where the wind is coming in and either replace the seals or put in some sealant
Old 12-03-2011, 09:24 PM
BasicConcepts's Avatar
Technical User
the seals are probably rotted 17 years does a number on rubber
Old 12-03-2011, 09:26 PM
TxPlates's Avatar
I did take a look at the rubber, all looks really well, but you're right probably not a bad idea to go ahead and replace it. Doesn't leak, so I can take my time, I was just more curious if it was normal.
Old 12-03-2011, 09:27 PM
Technical User
or when you get your new radio just turn it all the way up... thats what i do
iLL95's Avatar
I Like to Party
Super Member
It's pretty normal these cars undergo some wear and tear here and there (I'm a poet ) so it's not a bad idea to replace the small little components
Old 12-03-2011, 09:28 PM
iLL95's Avatar
I Like to Party
Super Member
Great point (I loled)
Old 12-03-2011, 09:31 PM
TxPlates's Avatar
Hahaha, that's exactly what I did the whole trip home in it
Old 12-03-2011, 11:12 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
or just take them out (weather permiting) then there will be a reason for wind noise
Old 12-03-2011, 11:23 PM
iLL95's Avatar
I Like to Party
Super Member
No seals?
Quick Reply: T-Tops - Wind noise?
