sway bar size ??
Hi, I ordered new sway bar bushings for my stock 94 --3.4 l ...front and rear, They don't fit..The I.D. on the rear bushing is to big and the front fits fine,however the stock bracket is to large for the o.d. What is the stock size sway bar,front and rear?....thanks...Id like to upgrade these to 35mm on the front and 21mm rear,I have 245/45 18 on the front and 275/40 18 on the rear,does that sound right? I have lowered the car by 3", if it matters. again thanks for the help and advice.
I think it's 30mm front 15mm rear - not sure though. I'm currently buying a used set of SLP sway bars for my project and they are 35mm solid front 21mm hollow rear. I have a 98 v6..
RS stock (and all V6 I believe) is 28mm front, 15mm rear
Z/28 stock is 30mm front, 19mm rear SS stock is 32mm front, 19mm rear 1LE SS 35mm front, 21mm rear Strano 35mm front, 22mm rear <--both hollow |
thanks
Originally Posted by libertyforall1776
(Post 591753)
