Summit Racing X-pipe kit
There's an X-pipe kit on Summit Racing for like $230. I think you have to cut it to fit the car, but how much would a shop charge to have this kit fit onto LT headers and have mufflers welded on.
I like the look of tips better. Suppose you could just cut off the turndowns and weld tips on?
Its very hard to run true duals on fbodies. The Rumbler dumps the exhaust before the rear tires because fitting exhaust piping out the back is challenging and sometimes impossible unless you have the correct suspension modifications or you reduce the pipe diameter and do not use mandrel bends. Kooks released their own full true dual exhaust setup, and it is extremely costly and still requires modification to the suspension, namely the panhard bar.
I know its not true duals but its still a good setup. If that car sells before I can buy it I'm going for an LT1 with an A4 that appears to have stock exhaust. i would have to buy LT's, and maybe that true dual setup you showed me.
