Struck By Lightning - Many Dash Lights On
1999 Chevy Camaro Z28 struck by lightning. The AC only cools a few minutes. These dash lights are always on: "Brake", "Low Coolant", "ABS INOP" and "Service Engine". I do not read any OBDII codes.ECM already replaced. What should I check next?
RE: Struck By Lightning - Many Dash Lights On
A lot of your sensors are probaly burt out and not sending any signal back to the ECM. Sorry wish i could help out more. One of the other guys will jump on here and probaly help you out a little more.
This is going to cause a ****load of problems man. Really unfortunate. Reset the ECM. See what codes you continue to throw. Go from there. Look for burnt wiring. I would go to a junkyard and ****** as many sensors as possible.
