Stripped intake thread
11/32 drill bit is what you use if you are tapping for a 3/8-16 hole. However, most heli-coil kits work by drilling and tapping to the next biggest size. The heli-coil will have that bigger size thread on its outside and the smaller thread you need on the inside. Those are how the heli-coils we use at the plant work..not sure if they are all like that.
This type heilcoil has the same pitch as the thread being repaired meaning you need special heilcoil tap with a larger diameter but the same pitch. That is why the tap comes with the inserts. That tap will define the drill size. The numbers I posted are from the heilcoil manual.
There are much heavier thread repair insert. This is a common insert used in industrial applications.
3/8-16 Inch Internal Size, 9/16-12 inch 36753580 - MSC
uh oh dont leave us for hollywood now crabby lol
Please dont make me panic guys. I have the 95 LT1 and the bolt size is 3/8. I ordered a helicoil kit from amazon yesterday. Drilling a bigger hole was what i originally thought i had to do to get the OEM size bolt in, which i hope is not the case since i dont feel to comfortable doing that. Below is the link to the exact kit i bought.
https://www.amazon.com/Helicoil-5521...%2F8++HELICOIL
You need to drill out the hole with a 25/64" drill bit, then tap the hole, then install the insert. Don't forget to use oil when tapping. Take a deep breath, go slow, and you'll be fine.
Honestly even with the discount they are over priced. I can find most stuff cheaper online. MSC is just so easy to use.rs657f
Do you have access to a drill press? If you can make a tap block it would make the process less touchy.
Tons of videos on youtube
I wish I had a drill press and a garage at least lol thats my next goal. I received my helicoil kit in the mail. It definitely isnt the one in the link but it will work. I see the tap is way bigger to create the 3/8 thread. Ill go get the bit and give it a shot this weekend.
Thanks for all the help again guys
The better Heli-Coil® kits come with drill bits
R1185-6 includes X drill bit, $26 at Grainger
https://www.grainger.com/product/HEL...Query=r-1185-6
DON'T FORGET to break off the install tab at the bottom of coil after installing.
