Strange Turn Signal Issue
Old 02-13-2012, 09:51 AM
nnewquist's Avatar
Default Strange Turn Signal Issue
'96 Camaro 3.8L
All stock except the wheels
I don't know how long it's been going on, but my wife noticed it when she was following me home from the in-laws' house a week ago. When my headlights are off, all turn signals work fine. When my headlights are on, all work fine except the right-rear turn signal.
I have very recently replaced the flasher unit and all the turn signal bulbs (front and back), so I am pretty sure none of those are the issue. Does anybody have a wiring diagram for this system so I could try to pinpoint where the problem is? I'm guessing it's a wire or relay somewhere...
Old 02-13-2012, 02:41 PM
mab6680's Avatar
i had the same problem but it was my front right blinker. i know you said you changed the flasher as did i (a few times) it turned out there was the wrong flasher was in there to begin with when i put a flasher that could handle more of a load it solved the problem for me
Old 02-13-2012, 09:17 PM
make sure you got the bulb in right. sometimes you can get it in backwards.
Old 02-18-2012, 09:55 PM
nnewquist's Avatar
Default Solved
Thanks SO MUCH! This was absolutely right. I turned the bulb around and it works perfectly
dsours69RS
67-69 I6 Tech
08-18-2021 11:31 PM
msp1055
06-01-2014 08:11 PM
sdotbailey
03-05-2014 09:56 AM
fastbenni78
08-28-2013 05:04 PM
wolfy692005
08-14-2011 11:20 PM
Quick Reply: Strange Turn Signal Issue
