Steel braided cooling hoses
Any reason other than looks to install these in place of stock hoses? I'm going to be replacing all the rubber lines in the cooling system and I figure a set of braided lines would look real nice. And on a quick search they don't seem too expensive, but then again that could have been a brand with a bad reputation.
What are some good brands, I don't want to unknowingly buy something with a bad reputation.
they are usually used in a high risk area like around belts. at least on boats thats where i see em. other than that for looks. if i were going to do it i would make sure they are stainless. steel would not last long around here.
For the car, you don't get the same pressure that you do in plumbing but if you like the looks, then go for it
