starter clicks
It's likely to be a bad starter solenoid. It's a stretch, but it could be a corroded wiring connection at the starter, battery, or a bad ground. Might as well start by cleaning all your battery, ground, and starter connections, since that doesn't cost anything but a little bit of your time.
Yea i will start on that. Asap. I did the top of the battery cables near the battery, evrythings fine there. i just have to lift the car up and start near the starter. is there any other grounds i should be looking at, other than just on the starter? thanks
The non battery end of the negative cable, you want to make sure the engine is well grounded. If none of the clean up helps, then check the start wire on the starter solenoid with a test meter to make sure you have at least 12 volts to it with the key in the start position (that requires having a helper).
