spoiler
RE: spoiler
You have to remove the rear plastic panel by using a screw driver to pry the plastic plugs that hold the panel but be careful not to break the plugs. They have been there a while to they may be brittle. Once the panel is off then you should see 4 bolts in the corners. Before you remove those screws unplug the center break light. You should he able to see the plug after you've removed the rear panel. Remove the 4 bolts mentioned and the rear spoiler should come right off. Installing the new spoiler is just as easy. Just revers the steps. Make sure you put some silicon where the bolts are before you tighten them to prevent water from getting in. Should only take you about 20-30 minutes to remove and install the new one. Have fun and don't hesitate to ask any questions if you need more help. P.S.!! Don't forget to hook the plug for the rear break light before you put in the new spoiler!!
RE: spoiler
dude thanks so much. i wish i was on this forum back when i had my old camaro. i was taking the damn rear bumper off..long story short it started out easy and then i was like "wtf" took me like a month.
