speaker question
Hello, i have a 1993 z28 with factory audio. Im planning on upgrading the head-unit along with all the speakers since the front two don't work, and the rears sound like they were made with tin cans. After doing some online research im finding that there was factory amps? Im thinking about just running new wires to all four speakers. How do i know if i have the amp or not? Its the factory system with the cassette deck, orange LCD screen and like 4 radio presets. Also what are the speaker sizes?, i peeked at the front two they look like 5-6.5"
so its not a bose system? if not then you have no amps and can use factory wiring. 6.5 is correct, some 6.75 will also fit. the amps if you have them are on the speakers and the base and its amp is under the plastic on the oposite side as the spare tire and jack. i like to use crutchfild to get an idea of what will fit.
Didn't Chevy get the AC Delco/Delphi units? And Pontiac the Bose? I still have my factory cassette laying around and it's Delphi, where else my Grand Am has Bose.
Any ways, you can cut the wires going to the amp and take two of them and connect them to aftermarket speakers with an aftermarket head unit installed, you don't have to run new wires unless you putting them on a amp. |
^ My old '95 Camaro had a Bose system, it was an option, else you got the AC Delco version...
Originally Posted by libertyforall1776
(Post 620967)
I admit after market HU are ugly.
try to put 1.5 din from Dodge charger or Jeep cars. those come with LCD. |
Okay cool thanks guys. Ill start digging into that.
Originally Posted by androzer
(Post 621071)
try to put 1.5 din from Dodge charger or Jeep cars, those come with LCD.
1995 Chevrolet Camaro Stereo Information
all I know that dodge charge 2007 is 1.5 Din and jeep cars also 1.5 Din. Google Image Result for http://i01.i.aliimg.com/img/pb/630/413/436/436413630_863.jpg Google Image Result for http://i01.i.aliimg.com/img/pb/740/275/429/429275740_698.jpg Google Image Result for http://i00.i.aliimg.com/img/pb/714/074/429/429074714_091.jpg Google Image Result for http://i00.i.aliimg.com/wsphoto/v1/528686376/4-3-Chrysler-In-Dash-Double-Din-Car-DVD-GPS-Navigation-Radio-System-With-Bluetooth-TV.jpg I dont know exactly if they will direct fit cus I had monsoon pontiac HU 2000 and I found it's screws not the same or sutable for camaro but It looks good :-) beside be aware the camaro has curve on th upper passenger side corner of radio trim. http://www.the12volt.com/installbay/...etail/486.html |
I'm fed up with the sound system in my 94 too. Mine has the factory Delco Bose system which got you an amplified speaker in each door and the subwoofer in the back LH corner. I don't know if the system sounded good in 1994 but I can tell you that it sucks now. I bet all the speakers have blown cones from the awful sound coming from them.
What's weird is that the base system for a 94 had 4 speakers. One in each door and one at each side of the back seat. On a car with the Bose system the rear grills are there but there's nothing behind them. No wiring either. People must have complained about this because the Bose system was revised for 95. It got 4 speakers plus the rear subwoofer. None of the speakers have the same part numbers as the 94 system. I keep hoping to find a wrecked 95 with the Bose system so I can get the wiring harness at least but so far no luck. |
