snow on christmas and a hit and run
well i just got this car fixed it from not leaking gas and everything well i parked in my driveway head out well i woke up some body hit it messed up fender and front end well whole reason makeing this thing how hard it is to change those out i know pull a part has a car same color and everything
It's not hard at all. There's more bolts taking the splash guards off than the fender itself. What year is your car?
http://www.bfranker.badz28.com/fbody...er_removal.htm
Once you get the bolts that hold the front end to the fenders off, the rest of it is just plastic retainers across the front of the radiator support and under the front. plus one revit on each fender bracket. It makes it alot easier if you have someone to help hold everything.
