Slight Driveshaft Clink on Accel. - Fix?
I get a Slight Driveshaft Clink on Acceleration, anyone know a Fix? It is as if the shaft is moving forward in the front when I have let off the gas and just tap it slightly, and is totally repeatable. Ring any bells for anyone?
TIA!
TIA!
No I haven't replaced them, but that will likely be next -- the donor car had ~95k mi. on it -- but I didn't think that sound would be from U-joints -- guess I don't know what the sound would be like from bad/tired U-joints?
I think you are telling me that my "clink" is the same as the "ding" or "dong" you are describing -- which could also be a "clang". LOL
Did I get it right?
Did I get it right?
I've replaced worn/bad u-joints before, and never was one ever very sloppy or making a clink noise. What generally happens first, from running dry, is you'll get chatter marks on the spider (the part the needle bearings in the cap ride on) which will then cause a vibration. With a clink, I'm expecting it to be play in the rear differential, or maybe your driveshaft slip yoke is close to bottomed out and whacking the tail housing on the trans.
To be honest, THIS is what I *think* it is -- what would be the resolution for that? It doesn't seem like there's anything that can be done... I only noticed this sound after swapping driveshafts...
