SeaFoam
Old Nov 12, 2007 | 08:37 AM
aleksandr's Avatar
Default SeaFoam
The instructions say:
With warm engine running, SLOWLY poor 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
So can I just open up my air lid and pour it down the intake? Like the red arrow shows in this picture.
http://img441.imageshack.us/img441/5599/imga0043ju8.jpg
Old Nov 12, 2007 | 10:44 AM
Redneck97's Avatar
Default RE: SeaFoam
i just put it in the gas tank.....
Old Nov 12, 2007 | 11:44 AM
aleksandr's Avatar
Default RE: SeaFoam
The sea foam site suggests doing both and also adding it to the oil.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Old Nov 12, 2007 | 06:43 PM
02StanGT's Avatar
Default RE: SeaFoam
I'd recommend sucking it out of the can with a vacuum line. Pouring it would be a wee bit difficult to control.
Old Nov 12, 2007 | 08:14 PM
TheStig's Avatar
Default RE: SeaFoam
Ok, you are all wrong, well I guess your all right too...
Poor an entire bottle into your full gas tank.
Poor half a bottle into your brake boost line.
Poor another half bottle into your oil.
And spray the deep creaper into your TB.
Here is instructions on how to do everything. read them very carfully & good luck.
http://ls1tech.com/forums/showthread.php?t=534376
Old Nov 12, 2007 | 10:19 PM
genvoodoo's Avatar
Default RE: SeaFoam
One other note is...make sure you have the ventilation. It will smoke like you wouldn't believe. Would almost seem the car is burning up. It does make a difference and enjoy .
Old Nov 12, 2007 | 10:37 PM
FunkyColdMedina's Avatar
Default RE: SeaFoam
sooo would this also work on a 3rd gen....in guessing so..i used seafoam in my tank the other day...no diffrence tho..and does it clean out carbon buildup on your pistons?
Old Nov 12, 2007 | 11:45 PM
02StanGT's Avatar
Default RE: SeaFoam
ORIGINAL: FunkyColdMedina
It will work. In the fuel tank, is more for cleaning out the injectors. Doesn't make that much of a difference. Sucking it into your engine via a vacuum line will make it smoke like crazy, and yes it gets rid of carbon buildup.
Old Nov 13, 2007 | 03:14 AM
Spartan66's Avatar
Default RE: SeaFoam
I put it in my crank case and came to find after my engine tick became fainter or went away (cant really tell..) but i found that i also have a ticking coming from where my cat was removed by the handymanwho previously owned my car...Long story short.. itreallydid its jobin myoil... I wanna run it thru my gas just to see the smoke lol.
Old Nov 13, 2007 | 03:29 AM
02StanGT's Avatar
Default RE: SeaFoam
You would have to put a lot in your gas to see your car smoke. Run it through a vacuum line to watch it make clouds.
