Rust 96 camaro
I have a 95 Camaro. It is constantly building rush but where has not been figured out. I have had several people to check it out. I have the motor pulled and was told the block was fine and did not have any rust. I replaced the water pump 2x. I flush it every couple of weeks. I replaced the radiator. I still have no idea where the rust keeps coming from. Oh, I replaced the heater coil also. Has anyone had this problem or know how to help?
You replaced pretty much everything but the engine block. Whoever told you the block was fine is right, as long as they scoped all of the coolant passages to visually see it was all clean. If it was an external "yah hey she looks good to me", then you still may have some built up sludge inside.
.an i found a flush can be good or bad ,i did one on my lt1 an there was so much junk in it flush made it worse ,sometimes they radiator needs replaced , could be from the bottom of the radiator ,collects in bottom over time ,an some anti freeze the good stuff from gm an an orange color looking rusty ,i was think it with mine ,but its just the orange color anti freeze ,an plenty slippery ,you can tell the feel in diffrence with rust an good anti freeze feeling with your fingers ,
The dex cool turn brown and looks like rust mud. Unless you coolant has been replace every 2-3 years you have a bunch of this mud all through the system. My 96 was dealer maintained its whole life. After it spun a bearing I replaced the motor with a used one. I flushed the motor and I flushed the radiator and got two handfuls of the mud from the bottom. I replaced all the hoses and the water pump. I put in the green anti freeze. 4 years later I still get some orange/brown crap in my overflow.
While I do not think most of what you are seeing is rust just old dex cool. Old coolant can cause rust. As the antifreeze breaks down it can become a mild acid and can cause the block to rust. Most likely your mechanic know its mostly dex cool. The first symptoms you will see from a rusty/acid coolant is rapid water pump failure and your freeze plugs will rust out long before your engine is in any danger.
