Rough Running
So, I fixed my previous problem of rough driving and weird idling... until today. It has been raining for the last two days and it was raining hard today when it started to act up again. I'm not too concerned because I'm about 90% sure it is the air filter sucking up water. My question is, how do I prevent my intake from sucking up water? Also, I was driving down the road and one of my windshield wipers flew off. What type of windshield wipers do you guys use? It seems that any of the ones I buy are loose fitting and don't work well. Thanks.
You've been cursed with early 4th gen wipers. I feel your pain. The best replacements I found were Trico 24-9R blades from Advance, but you can always buy wiper refills for much less on the interwebs.
I buy ACDelco blades, but I get them cheap from my job (:
How is your filter sucking up water, is it dragging the ground? Have you replaced the plug wires? Leakers can make an engine run rough when there's a high moisture level in the air (rain).
Originally Posted by Z28Freak
(Post 531943)
look up under there and make sure the deflector/cover is on. what kind of cai do you have? agree with 69 is more likely a spark problem. i would suspect plugs, plug wires or opti. mine somehow gets water on/in the ecu when it rains really hard so i have a freezer baggie covering it. i was throwin a code with that. speaking of that are you seeing any ses light or had it scanned for codes?
I don't see how your intake would be sucking up water unless you were driving through pretty deep puddles.
I live in Washington and drive my Z to Portland, OR all the time. Lots of driving in lots of rain. Not the most fun for handling, but I haven't had a sputtering problem since I replaced my opti and wires. You probably have some weak plug wires or an opti that is getting old. How many miles on your ride and when was the last time the plug wires and opti were changed? |
there is at least one kind of cai that has the filter hanging way low. dont recall what the brand name was but i remember the guy had real problems with water.
It's just a knock off CAI off Ebay. But I don't think it's the opti because it doesn't run bad all of the time. I have had a feeling it was the spark plugs for a while now, I just don't want to change them. It's a PINA.
Be sure you get the correct wiper part number, my old '95 had some oddball wiper blades that weren't readily stocked at all stores -- check your Owner Manual and get the correct part!
As for your CAI -- pictures replace a million words... ;) |
| All times are GMT -5. The time now is 07:44 AM. |
