Rims for my 94' camaro
I am looking for new rims for my camaro, nothing expensive, nothing out of the ordinary. I need 4 new tires so I was going to get new rims with them as well. I found a good cheap price on 4 18" 2011 stock camaro rims, the black ones, with tires on them. It says the bolt pattern is 5x4.75, the same as 94 camaros. I have read in different forums and what not they won't fit, while some say they will. So my question is, will the 2011 camaros rims fit on the 94 camaros?
here is a good place to look http://www.camaroz28.com/forums/showthread.php?t=312442
another http://www.camaroz28.com/forums/showthread.php?t=428890
It won't work, fitment issues create problems. Bolt pattern on the 5th gen is smaller, and the actual height difference is around 3". It can be done, but without modifying then no. Then you would have to worry about the offsets as an entirely different issue on the 4th gen compared to the 5th gen fitment.
4th gen: 5x120.65mm
5th gen: 5x120mm
Possible to use, as some do. But you'll have to watch those studs.
4th gen: 5x120.65mm
5th gen: 5x120mm
