How can I reprogram the courtesy lights?
The courtesy lamps in my 2002 stay on for 10 minutes after a door is opened, as it says it should on page 2-61 of the owners manual. with delayed Illumination (pg. 2-62) I should be able to shorten that.
I tried to enter Programming Mode using instructions on page 2-21 in order to turn on Delayed Illumination, but I can't figure out the procedure. To be able to remove the radio fuse (step 4), the door has to be open, which seems to cancel the process. When I turn the key to accessory, I hear no chimes.
How is it done?
How is it done?
I gave up
I guess rhe car is old enough to have issues that cost more to get fixed ( by a dealer technician) than they are worth.
