reverse bulb
i need to know the reverse bulb size number TIA ✌🤗
You need to give a little more information for a person to know what year car you're working with. Since you posted this in the fourth generation section I'll give a couple of different bulbs that may cover your car. A 1994 Camaro uses a 1151 backup bulb which may be the same through the 1997 model year. A 1998 through 2002 model year should use a 3155 bulb.
Originally Posted by peterpar
(Post 732505)
1 Attachment(s)
Here's a bulb chart from the 1995 service manual.
thank you so much for the information
