Replacing the Opti with a distributor?
It can, and has been done, but why do you want to do that? Most of the applications I've seen done are in the C4 Vettes, or when an LT1 is put in an older car. The rear of the intake needs to be drilled open, and an angled spacer needs to be made/attached to the intake so the distributor sits right. Your main issue would be with not having any vertical clearance under the cowl to drop the distributor down in. As well as other wiring or computer issues you may run into. As bad of a positioning design as the opti is, it's in front because there is no room in back. When you consider the good majority of factory optisparks lasted upward of 100k miles, a good replacement one should outlast your ownership of the car.
There was a guy (LT1intake.com) who used to. No longer does, and the link is dead. I've also seen a guy on ebay who would convert your intake.
I can't imagine doing these conversions is much of a get rich business though, which may be why these guys have fallen out of sight.
If I remember right going the other direction would be a lot easier. Ls1 type ignition. We had a thread here with a lot of info in it?
You would, so the injectors know when to fire. Another reason why it would be more hassle than it's worth, you're not totally getting rid of the opti. If you wanted to put the LT1 in a different car and turn it old school with a carb, that's a different story.
There are a couple different options. An LTCC LS1 coil to plug conversion, which retains the opti for triggering purposes only. Bailey LTCC setup Greenarrow here has done that conversion on his car. Or EFI connection makes a conversion that totally removes the opti. It has it's own crank trigger, computer, and it's expensive.
