Replacing alternator..tensioner help
I need to replace my alternator in my 95 v6 3.8, but i am not sure how to loosen the tension on the belt so i can take the alternator off. I have included a pic of the tensioner on my camaro and i need to no exactly how to loosen the belt...thanks
ORIGINAL: thekidd3010
Just get a socket on the black pully and if you're not sure which way it goes try pushing one direction and then the other. You'll see the tensioner give and you should notice the belt loosen up. Pretty easy.
thanks i fixed it and got the alternator on, but when i took it for a quick drive then popped the hood it was really hot an i smelta little smoke, any ideas of what can be wrong or could it be because it has been sitting for a while??
