removing stock plastic grille
i just my billet grille and i can't figure out how to remove the original plastic grille, the instructions say you bend it up from the bottom and cut the plastic studs, but i can't for the life of me bend it upwards even an inch. and i dont want to pry it up with something in fear of scratching the paint. anyone have any suggestions?
RE: removing stock plastic grille
With the aftermarket grilles, I was under the impression that they screw directly into the stock one. Are you sure you are supposed to remove it? Sorry for not being much help, that's just what I thought.
it depends on the grille, some of them do screw in and others replace the stock grille.
and im pretty sure you just pry it out. |
the instructions for my billet grille tell me i have to remove the stock plastic one. the billet grille i have is pretty thick, I'd say a good 2" thick, so i cant put it ontop or it will stick way out and look retarted. i guess ill just pry that ***** out. hah ill get pic up of it when i get thenew grille in.
